Materials Dialog Box Doesn't work
Message 1 of 12
When i try to change a material or access the Material Dialog Box, nothing happens. Have tried to repair the .msi files. All .adsklib files are also present. Tried to add paths in File>Options>Rendering. Have also tried to reinstall Revit 2018. Can anyone help?
From what i can gather, everything is present, it just doesn't want to work.
Thanks in advance! Cheers!
Janis
PS I'm running Revit 2018 Student version
Replies (11)
Message 2 of 12
So Materials under Manage tab doesn't work at all?
Message 3 of 12
ennujozlagam
Hello, try to refer website below and see if helps. Thanks
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/simplecontent/content/why-d...
Message 4 of 12
I am having the same issue.
I have tried the above solutions and reinstalled the software. I have run out of ideas. Has anyone got any suggestions?
Message 5 of 12
No, I click on it and nothing what so ever happens
Message 6 of 12
I have the same problems ever since installed Revit 2018. What is your Windows version?
Message 7 of 12
stewartjex
Community Visitor
Community Visitor
I am on windows 10.
Message 8 of 12
Same here, Windows 10
Message 9 of 12
Solved It!
The issue for me was with the graphics card. Disabling the graphics card in device manager and turning off hardware acceleration fixed the issue.
Message 10 of 12
richard.horner
Observer
Observer
I too had this same problem, which only occurred after updating my Nvidia Driver last week. As suggested by Stewart Jex, I turned off Hardware Acceleration from within the Revit Options dialog, then re-started Revit. The Materials Dialog re-appeared. I went back into the Revit Options, and turned Hardware Acceleration back on, followed by another Revit re-start, & everything seems to be working correctly. Material Dialog works fine & hardware acceleration is on.
Message 11 of 12
AAAStructural
Thank you for posting this.  This has just happened to me.  It was great to find this post.
Message 12 of 12
aRcHiTeCt.JM
... did you try disabling your graphic card ?
.... or disabling your acceleration card
aRcHiTeCt.JM
REVIT EXPERT ELITE
➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ ➪ is it working for you ? ➪ ⇩ 'Accept as solution' ⇩ ⇦
