Material Volume is missing in schedule
shefypattambi
Message 1 of 14
shefypattambi
Dear All,
Please give me a solution for this..the beam material is showing for some element and  for some element it is showing as 0.00. All the members are from the same family and type.
Replies (13)
Message 2 of 14
FGPerraudin
Hi Shefy,
It s very difficult to suggest any solution simply based on that picture...
Could you maybe send a file? containing a beam and you schedule?
François
Francois-Gabriel Perraudin
BIM management and coaching
Message 3 of 14
semko_dm
Hi!
Could you attach this family to help us better understand your issue?
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Dmitriy Semko.
Dmitriy Semko
BIM-Manager
Blog
Facebook | Telegram | LinkedIn
Message 4 of 14
shefypattambi
Please find the file from the following link. This is a smaple file and please check the structural frame schedule.
https://drive.google.com/open?id=0Bw6GA2wGIVm3dUpkUnhEZ0ZhbVE
Message 5 of 14
semko_dm
As hotfix, you can use element Volume instead of Material Volume.
Dmitriy Semko
BIM-Manager
Blog
Message 6 of 14
semko_dm
The thing is that columns and beams are joined wrong. In screen capture below you can see sort of phantom geometry inside the column. That fantom belongs to highlighted beam and gives us zero material volume.
If you disallow join and trim the beam to the column surface, that's phantom and zero material value will disappear.
Kind regards,
Dmitriy Semko.
Dmitriy Semko
BIM-Manager
Blog
Message 7 of 14
shefypattambi
Excellent Reply Thank you..Smiley Happy
Message 8 of 14
semko_dm
You are welcome Smiley Happy
Dmitriy Semko
BIM-Manager
Blog
Message 9 of 14
shefypattambi
Did you access the disallow join option by right click mouse?
I think this option is gone in Revit 2017.1 version
Message 10 of 14
semko_dm
I'm already on revit 2017.1 and it's still here under right mouse click.
Dmitriy Semko
BIM-Manager
Blog
Message 11 of 14
semko_dm
But be careful, after this join\trim
actions , you must check your analytical model.
Dmitriy Semko
BIM-Manager
Blog
Message 12 of 14
shefypattambi
Now disallow join is appearing once I right click on the drag end bubble. Did you try "switch joint order command'' option. it will eliminate that null volume from schedule and also it would not affect our analytical model.
But I feel that there is some problem. In previous version of Revit  I am always draw the beam from center to center and the beam will cut back depending upon the bounding box set in the beam family. But in this case the bounding box is not working as intended. I have to investigate more.
Message 13 of 14
semko_dm
I won't tried "switch join order command'', but you are right it's the best way, and it have no problem with analytics.
Dmitriy Semko
BIM-Manager
Blog
Message 14 of 14
Thank you very much! I had the same Issue and finally solved.
