Material takeoff gives wrong values for generic model
erdem_adali
Message 1 of 15
erdem_adali
I create two component (model in place or family, doesn't matter). 100x100cm cubes, one as generic model and second as wall. And paint one of their faces.
Material takeoff for wall shows 1 m2 paint. No problem, 100x100cm face is equal to 1 m2.
But material takeoff for generic model shows 6 m2 paint in my computer, 2 m2 in my colleagues computer!
Our company produce facade claddings. we use paint tool to calculate the  certain surfaces areas of our products.
Does anyone has an answer? What is the cause or solution?
Replies (14)
Message 2 of 15
That's just the way Revit calculates. Paint is a good way to go.
Message 3 of 15
Message 4 of 15
erdem_adali
Thank you for your respond.
What do you mean with "That's just the way Revit calculates."?  Does Revit gives random values for paint on generic model? Is there no solution?
We are a facade firm. Architects mostly model their facade with generic model element. We calculate our quantity over their models. Thats why i can't say "oh ok, i will make my models with wall element now on".
Message 5 of 15
I think you misunderstood me - or I misunderstood you.
I merely confirmed that Paint was a good and widely used approach.  Other than that, you should expect - and get -close to dead on ballz accurate MTOs from Revit.
Are you aware that you can also Paint Surfaces in a Family with a Paint Parameter?
https://www.youtube.com/watch?v=3J5fYF2eaks
Message 6 of 15
erdem_adali
Answer for my own question ; Even if you only paint only one face of a generic model, materiall take off gives all area of all faces.
For example: i create a 1x1m cube. Paint only one face. But material takeoff gives 6m2 quantity, all surface of the cube.
But if i paint another surface with a different material materiall takeoff gives true values. 1m2 quantity for both material.
Message 7 of 15
I don't understand your solution, but it sounds like you are using Paint as per my suggestions above.  However, your conclusions sound flawed:  "Even if you only paint only one face of a generic model, materiall take off gives all area of all faces."
Message 8 of 15
erdem_adali
You have paint all the faces of the cube. thats why revit gave you the correct values. Try to paint only one face, it will say 6 SF again. Paint two face with same color, still 6 SF.
But if you paint one face blue and other face red its gonna say 1 SF blue and 1 SF red.
Message 9 of 15
I still don't understand your conclusions, but only 2 faces of the cube in my previous screenshot have a Paint Parameter applied to them.  The cube geometry's Material is "Blue".
Maybe these 2 screenshots will help clear up the confusion.  In the first screenshot, there are 2 cube families; one with 1 side painted and the other with 2 sides painted. Both cube geometry's Material is the one named "Default".
In this screenshot, no faces have a Paint Parameter applied to them:
Message 10 of 15
You know, I'm starting to think that your issue "Material takeoff gives wrong values for generic model" is due to the way you constructed your schedule - not the way you constructed your family.  What do you think?
Message 11 of 15
erdem_adali
Aha! We were not choosing any material for generic model. We have only created the model and paint one face.
You selected "default" for the generic models material, so it says 1sf red and 5sf default. We didn't think it was necessary.
Okay, it's easier to choose a material than to paint it another color. Thank you.
Message 12 of 15
Huh?  What does all this mean and why do you keep marking your own posts as the "Accepted Solution"?  Please provide a lucid solution.
Message 13 of 15
info8XB2Y
Community Visitor
Community Visitor
Are you dumb? He finally found the solution to this whole debacle, which we were all looking for. Revit calculates the area from all the faces of the model. If you don't assign a material to your family "rather than accept the ""by type"" parameter", and then paint one of the faces with a specific material, you can filter our the area of one face by Material Name. Now the general global public can finally create area schedules in generic model families using a multi-billion dollar company's software, which they cannot bother to update to workeable standards.
Message 14 of 15
p.rikaniemi
I also noticed the same behaviour of the painted material calculations as described before.
An additional thing I'm noticing is that if you have a generic model with a painted surface and cut that model with a separate void family, the area calculation of the painted area becomes larger when it should be getting smaller. If you cut the generic model within the family editor (=not with a separate family), the area calculation is correct. Does anyone know why this happens and if there would be a way to use a separate void family and still get a correct area calculation?
Message 15 of 15
p.rikaniemi
Okay, I already found a work-around that works for me. If I use a second solid generic model and join it with the one I want to cut, then place the solid on a workset which I then turn off, the element gets cut and the area calculations are correct. Voids for some reason don't work correctly for me except if they are inside the same family as the solids.
