Material Tag Missing.
Orihalcon96
Orihalcon96
Hi Everyone.
I found a problem about material tag. Its always missing after i close REVIT / close views.
Is there any a solution about this problem?
Btw i'm using Revit 2023.
Thanks.
Need a heck of a lot more info than that to be able to help you.  Maybe posting your file would help us to help you. Let's try that and see.
anze.kumar
Depends on which parameter does the mMaterial Tag refer to (comments, Description,..)
Could also be that the material "lose" connection to your library and therefore cannot show the value provided in the parameter.
