Material Tag location in Revit 2022
Emmanuel.BoakyeNHKVA
Message 1 of 10
I'm trying to load a material tag family into my project, where can I find the material tag annotation family in the autodesk cloud family library?
Replies (9)
Message 2 of 10
juliar123
I clicked on the Load Autodesk Family tool. In the dialog box, on the right side, I selected Annotations, and then typed in Material in the search. One Material Tag popped up for me.
Hope that helps!
Message 3 of 10
Very strange because that's exactly what I've done and I get 'No search results found'.
Message 4 of 10
juliar123
Are there any other families showing up in the dialog box? Open up another session of Revit and see if you can access it from there.
Message 5 of 10
All the other annotation family tags show up in the dialog box but it seems there's no material tag in the list
Message 6 of 10
here.
BTW: if you have the Material Tag placed in other Projects, you can use Transfer Project Standards to transfer it between Projects. If you have a Material Tag in a previous Version of Revit, you can load that one into your 2022 Project.  It will upgrade automatically on loading.
Message 7 of 10
Open any tag family, change category to material tag and save as a copy.
Message 8 of 10
Would love to download this but unfortunately the company that I work for has a policy which doesn't allow downloading of files without it being audited by the senior management first, its all a bit of long process...
Message 9 of 10
Pull the Tag from another Project or Library then.  Bada Bing.
Message 10 of 10
Yes, this worked!
