Material skewed/distorted when applied to imported object
I have tried different file types including dwg, dxf, sat. I tried different meshes with different densities. I cannot seem to get the material to map onto the surface properly, as can be done with a Revit object. (see wall on the left)
These shapes were extruded but I have tried solids too and I have the same issue.
Please let me know if there is a way to fix it.
Many thanks!
dzanta
did you try going into the Material Dialog Box, your material, texture mapping...adjust accordingly.
Dzan Ta, AEE, ASM, ACI.
Autodesk Community | Twitter | YouTube | Facebook | LinkedIn |
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Did you ever find the solution to this problem? I'm having the same issue with my objects imported from SketchUp
