Message 1 of 16
08:06 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi all
I'm struggling here. I need to make a schedule for a wall with the materials separated with there thickness/width separated. I have already done a Material Takeoff but it gives me the overall thickness of the wall and not the separate thicknesses.
For example if a wall is 260mm thick made up of 15mm Sound Block, 15mm Sound Block, 50mm Gypframe, 100mm Thermal Layer, 50mm Gypframe, 15mm Sound Block and 15mm Sound Block.
Now when I put this into a Material Takeoff Schedule the thickness of each item is 260mm and not individualised. I have attached a screen-grab of what is coming up.
I hope someone can help. I would be very grateful.
Kindest regards
Mateen S.
