Material schedule help
kherrman
Message 1 of 22
kherrman
I am trying to use a material takeoff schedule to create a material key for exterior elevations.
Thought I had it figured out, but for some reason, not all of the materials show up. I just include the fields Material Mark and Material Keynote. Brick shows up, but shingles do not.Screenshot 2021-03-29 131201.jpgScreenshot 2021-03-29 131238.jpgScreenshot 2021-03-29 131307.jpg
Anybody with an idea of what is causing this?
Replies (21)
Message 2 of 22
cbcarch
Fill in the "Comments" field in the Roof material like you did the Brick.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 22
kherrman
I was hoping that was the easy fix, but it isn't. I have other materials that the comments section was filled in and they are not showing up either.
Message 4 of 22
cbcarch
It's probably something to do with the way the Schedule is Filtering.
Edit Schedule> look at the Fields, Filters, etc.
Cliff B. Collins
Message 5 of 22
kherrman
I have no filters and the only sorting is by the Material: Mark and it's ascending.
Message 6 of 22
cbcarch
Is the Phasing of the Material Schedule set to New Construction? ( assuming you are using Phases such as Existing & New Construction.)
Cliff B. Collins
Message 7 of 22
kherrman
Everything is new construction
Message 8 of 22
cbcarch
Just another thing to verify:
Check your Keynote txt file location--make sure it is reading correctly.
Annotate Tab>Keynote>Keynote Settings
Cliff B. Collins
Message 9 of 22
kherrman
Message 10 of 22
cbcarch
Can you post a copy of your Revit model so we can take a quick look?
Cliff B. Collins
Message 11 of 22
cbcarch
Since you are assigning a Keynote Value to all the Materials, have you tried using a Keynote Legend instead of a Material Takeoff Schedule?
Give a try and see if it works?
Cliff B. Collins
Message 12 of 22
JavadHamidi
Upload  your file, please
then we can say the reason more properly
Message 13 of 22
kherrman
any trick to make the file smaller? it's 100mb
Message 14 of 22
Did you ever consider that the SR Material isn't being used?
Message 15 of 22
kherrman
It is used, as well as other materials that are not showing in schedule.
Message 16 of 22
What Category are you Scheduling?
Message 17 of 22
I'm not even sure I understand what you are doing.  A Material Key for Exterior Elevations?  Can you explain?
Message 18 of 22
kherrman
Instead of writing notes, I use a key to call out exterior elevations
Message 19 of 22
How did you create your "Material Key"?  That was my question.
Multi-Category MTO?
Message 20 of 22
kherrman
Your question just gave me the answer. I created a schedule via material takeoff and selected wall for the category. So this schedule is only showing materials on walls. I think I can fix it by selecting the multi-category.
