Error during PDF printing in Revit 2021
6 ANTWORTEN 6
GELÖST
Nachricht 1 von 7
davidMTPP8
654 Aufrufe, 6 Antworten
I am unable to produce combined PDF prints in Revit. I am currently using Revit 2021.1.2 This is also the case with Revit 2021
The software keeps shutting down whenever I am printing combined PDF.
This is the error message I keep receiving. Please help, this has become too frustrating
David
6 ANTWORTEN 6
Nachricht 2 von 7
zeulrick
als Antwort auf: davidMTPP8
Have you tried purging the unused families and types in the manage tab? This can reduce the file size and minimize errors.
Nachricht 3 von 7
syman2000
What is your computer spec? As well did you try to change your PDF DPI output to 300 or 600DPI and see if that helps. Also check to see if you change your print from presentation to Medium.
Nachricht 4 von 7
davidMTPP8
als Antwort auf: zeulrick
I have and it brings another error
Thanks for recommending purging though.
[image: image.png]
Nachricht 5 von 7
JavadHamidi
Hello
I suggest to divide your printing set to smaller sets
Nachricht 6 von 7
paulauskas.linas
It is windows update problem. Uninstall update.
Message 8 in this post
https://forums.autodesk.com/t5/revit-architecture-forum/too-many-system-resources/m-p/10198432/highl...
Nachricht 7 von 7
davidMTPP8
als Antwort auf: paulauskas.linas
It was an update on Windows 10.
I uninstalled recent windows updates and now I can print combined PDF from Revit
I am very grateful
