Material Override View Specific
I am trying to show the wall stud hatch as grey in plan and white in section views. Here is the challenge, I can easily set up a view template override for my sections that changes the wall hatch to white. The problem is, I still want to be able to see the plywood and gyp hatches.
The template overrides don't allow a material override just wall overrides.
I also checked under the material. I can change the cut pattern and the surface pattern but that isn't plan or section specific.
Any ideas on a material override that is view specific?
cbcarch
One possibility is to use Parts, which allows you to control each individual component/layer of a compound wall, in any view, such as Plan or Section.
Take a look here:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2016/EN...
It is a bit complex, and must be well understood by all team members before implementing--but I think you can achieve what you are after using Parts.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
