Material Library
Material Library
Material Library
I just upgraded my Revit from 2015 to 2017.  In 2015 I was able to create a new material, go to the appearance tab, and select a jpeg file from my computer.  I can't seem to find how to do that in 2017.  Any help is appreciated.
Sahay_R
Double click on the highlighted image swatch. That will allow you to browse for images.
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
as Rina Sahay said you can find it in the appearance tab. just some thing to add, that you can upload the picture that you have on your computer, from under image text, written no image selected.
If you find my post is interesting, I will Appreciate it if you give a Kudo.
If it solves your problem, please click Accept Solution.
