Material Libraries
Material Libraries
Message 1 of 20
Material Libraries
I came to know that I am not having Advanced Material Library Medium Image on my system. When tried to do it from MSI Files (Installation Files), an error occur saying something like -  ".../ILM/common ~1.cab is missing". Now I don't know from where I can download Advance Material Library Medium Image. Please provide link of it, and also provide link for PLM (Prism Medium Image Library). I don't find any High Resolution Libraries in my package of Revit 2020 Student Version (Updated to Revit 2020.1). Kindly share link of High Resolution libraries also if available. Thank You.
Replies (19)
Message 2 of 20
Ahmed_Muharram
Check this out
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Ahmed Heteba, PMP, bsi, B.Sc, AEE, ACI, ACP
Senior BIM Manager @ EllisDon
Message 3 of 20
The link you gave for troubleshooting seems like it is changed. It's showing page not found error.
Message 5 of 20
Thank you for reply but I checked I'm not having problem loading material library I'm having problem installing it. I need link of setup file for Advance Material Library Medium Image (if you getting my point !!)
Message 6 of 20
Are you saying you don't have Autodesk Materials Library?
This Infraworks link has a Link to them...
https://knowledge.autodesk.com/support/infraworks/learn-explore/caas/CloudHelp/cloudhelp/ENU/IWGetti...
Message 7 of 20
Thank you for sharing links. I am now able to download libraries and install it.
Message 8 of 20
I uninstalled all the materials bc after I downloaded Revit LT 2021 I was having material issues. So I uninstalled all of Revit LT to my best ability. Now it says it can't find the library to install it.... I'm so confusedpraise gebus.PNG
Message 9 of 20
 Why don't you make it easy on yourself and just uninstall and reinstall the Material Library? That's what I would do.
Message 10 of 20
I must be missing something bc I have tried that many times
Could you please screencapture where I should look to make sure all is uninstalled? I have been reading forums all week trying to resolve this
Message 11 of 20
Message 12 of 20
followed the instructions, I feel confident that there are not any libraries on the computer, ran the materials library first and got this messagepraise gebus 2.PNG
Message 13 of 20
Is there another way to uninstall material libraries?
Message 14 of 20
or check to see what materials I do have loaded. PLants are green and glass is translucent but I cant add or change anything
Message 15 of 20
I thought you confirmed that you DID NOT have Materials installed?
If you had them, they would be here:
C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\20XX
C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures
Message 16 of 20
I was sure I deleted them all, I am still getting the same message that I need the library so it can be accessed to install it praise gebus 2.PNG
Message 17 of 20
Where do I find these or how do I download them to find them?
Message 19 of 20
joiceipm
estou precisando baixar a MaterialLibrary 2022 (não foi disponibilizado junto com meu revit educacional)
Message 20 of 20
bonaventure.ngwu.200175
Hello guys, please how can I download revit 2016 material library?
