Material Libary Re loading every time it is opended
When the Material library is opened it loads all the materials taking a few minutes but after it is then closed and opened again it has to reload them all again every time.
I have reinstalled Revit and the same issue still arises, it also happens within all other projects that i open.
Im using Revit 2021.
Yes that is the issue it has to reload them every time the window is opened, is there a fix there doesn't appear to be one?
