Material Color Changing(Glass)
Mohamed_Arshad
Advisor Advisor
6,910件の閲覧回数
11件の返信
メッセージ1/12
Mohamed_Arshad
Hii Guys!!!
I need to create blue color windows like below image.
I change material properties but it is not appearing in my file kindly see blow image, color not coming.
Mohamed Arshad K
Software Developer (CAD & BIM)
0 件のいいね
解決済み
6,911件の閲覧回数
11件の返信
返信 (11)
メッセージ2/12
mauricio_mssf
It is difficult to see why the image is small and without much information.
The transparency is at zero, it should appear as a green solid (if it is a visual style in consistent colors);
If you have a realistic visual style, to change the color you must go to Appearance, and choose which option is best for you:
1) Changes Color to green, or
2) mark Tint - and change the Tint Color, as image bellow.
And make sure that the glass material you created is the material that is applied to families.
If it won work, you can send the file for a better analysis. 
If the answer solves your problem, click Accept as Solution this helps other users to quickly find an answer and let a like if you liked it.
Você achou esta postagem útil? Sinta-se à vontade para curtir esta postagem.
Ficou satisfeito com a resposta à sua pergunta? Nesse caso, clique no botão ACEITAR SOLUÇÃO.
 Mauricio Santos Filho Arquiteto | BIM Manager
0 件のいいね
メッセージ3/12
FWIW: I wouldn't set a solid-colored Graphic Surface Pattern to the Glazing's Material because that solid color will show in all Elevation Hidden Views and Wireframe Views by default.  If you want some Elevations Views to have that "colorful" effect, then apply the solid-colored Surface Pattern as a View Override through VGOs by Element, Category or Filter.
Alternatively, you could check "Use Render Appearance" for Graphic Display.
0 件のいいね
メッセージ4/12
Mohamed_Arshad
I tried this but color not appearing in my project, What to do next...
Mohamed Arshad K
0 件のいいね
メッセージ5/12
mauricio_mssf
Post the file, it will be better to analyze what is wrong.
0 件のいいね
メッセージ6/12
martijn_pater
Check if there is a different material override for the glass (sub)category in object styles under Visibility Graphics. You could also use this for view specific overrides.
0 件のいいね
メッセージ7/12
You need to check the box next to "Use Render Appearance" on the Graphics Tab.
0 件のいいね
メッセージ8/12
Mohamed_Arshad
Hii
I have attached the family file below kindly find the attachment.
Mohamed Arshad K
0 件のいいね
メッセージ9/12
martijn_pater
You need to associate a material parameter and/or a subcategory to control the material of the glass geometry in the project. If you need transparency in elevation, check elevation transparency for the opening cut.
associate material parameterassociate material parameter
elevation transparencyelevation transparency
0 件のいいね
メッセージ10/12
解決済み
I suggest this 11 step workflow:
0 件のいいね
メッセージ11/12
Mohamed-Nassar
change the picture or texture from your point of view and check it with detail level and visual style
If the above reply answers your question; Please mark it with ACCEPT SOLUTION
Mohamed Nassar , ACP, Autodesk Ambassador Gold
BIM Support / Structure Modeler
0 件のいいね
メッセージ12/12
mauricio_mssf
解決済み
As I said, there was no parameter to check the materials, there was no subcategory attached, I put a parameter to control the type of material, the glass and the frame, and I changed the configuration of the glass material as I and @barthbradley said before.
0 件のいいね
