Material Browser Freezes after upgrading to 2022.1.6 Hotfix
john.deleonQDFBH
john.deleonQDFBH
Hello
My material browser is not freezing after upgrading to 2022.1.6 hotfix.
I cannot enter values in the Material Mark.
It was working before the upgrade.
How can I fix this?
It's been talked about before. The workaround is to populate that Material Identity Data through a Tag or a Schedule.
john.deleonQDFBH
So this issue is also present in Revit version 2023.
Is there a way to uninstall the hotfix.
I am a professor and my videos are prerecorded for my students showing how to add marks for materials.
I would rather make this work the way it's designed than use a back door.
We need a new hotfix to fix this issue.
john.deleonQDFBH
Thank you Autodesk for releasing Hotfix version 2022.1.7 which fixed the issue.
Case closed.
