- Mute
- Permalink
- Report
I've made a 9-point adaptive component to place on a curved mass. These components are defined as curtain panels.
There's a material assigned to the different faces of the panel. Top, bottom and the edges.
I've noticed when creating a schedule to calculate the total areas, it gives me the top surface as well as the edges as one surface area. But not the bottom area. Additionally I can't seems to extract the seperate areas of the 3 materials.
When I apply the materials in the family as a painted material/parameter, the result is the same.
I need to be able to extract the exterior side of the panel. Any suggestons to achieve this are welcome.
In the attached file you'll find 4 types with different thickness or gap size.
The placement points are the same for the 4 panels. (Revit 2017)
Please use "Accept as Solution" and give kudos as appropriate to further enhance these forums. Thank you!
