Matchline is Inconsistent
The matchline that I have created on two plans are different lengths. I would like it to show up uniformly. It is set to unlimited so all matchlines should be the same right? The scale is also the same on both plans
Have you any Graphic Overrides applied by Element or Category?
I've just check and no. I do not have any graphic overrides. The Matchline is the same length as when I edit it yet but it returns to its two diffrent lengths. I dont know if thats a Graphics driver issue or an API issue. I am working on R2020 so maybe they have lots of glitches to fix? I attach png image
Check View crop / annotation crop regions.
Thanks buddie! It was the annotation crop. Since I had same view templates I assume that it should be universal and I did not have the anno crop on some views. Thanks .
