massing
massing
massing
WHen I insert a mass into my topography I get this message :The Mass contains geometry that cannot be combined.   Mass Floors, volume, and surface area, won’t be computed. Therefore I am unable to create floors adnwalls, roofs etc.
Alfredo_Medina
If you want to create mass floors, the family that you are loading must be of the Mass category, and the objects must be created in the mass family. You can still create roofs and walls in the project with families of other templates, such as the generic model adaptive template, though, but not mass floors. Did you make these forms in the mass template, with the Create Form tool? or you imported all this from another application?
Yes I imported all from the massing template.  However one form is a nested into the other form. But even so it is a mass template. So based on what u have mentioned it still must work.
Sent on the go with Vodafone
