Hi
I have a project that was done on Autocad and I liked to redo it again on Revit. The attached files include the mass that I am facing some difficulties with 😕 after creating the mass I cannot edit the profiles of the upper lines to reach the actual design! I get "Unable to create form element: self-intersecting or singular geometry would result."
I tried to create each face (as a mass) alone, but I get a message says "Mass contains only mesh geometry, which can’t be used to compute Mass Floors, volume, or surface area." I ignored the message but it doesnot possible to add a roof because the surface is "broken" not smooth! The broken surface existed in every different try
Can this be done on Revit??
* in AutoCAD I did it using mesh modeling
I would appreciate it if you can help me with this!
I have the same problem too.. I made a family mass, then I loaded into Project. When I want to make the mass floors I CAN'T because "it's only mesh"
I model Everything on Revit... Any solutions?
The first problem is not the same as the second problem. In the first one, the user needs just 1 surface to make a roof, which can be done with 3 parallel splines of 3 points each. Create form, and then modify the location of the points. Load into project and create Roof by face.
The second problem requires a volume, not a surface. Once you have a volume, you can insert it into the project that has levels, Select the mass, and create mass floors at the desired levels.
I created a complicated surface but when I upload it into the project, this error appears "mass contains only mesh geometry which can't be used to compute mass floors, volume, or surface area" .. So I can't create a roof out of it .. I searched for the solution a lot and it seems that I have to convert it to 3D solid geometry so how can I convert it or how can I solve this problem with any other methods
so, what is your problem?
Revit says you can not do all this because it is a Mesh ( a surface without thickness) not a Solid Form . But certainly you can make a Roof or Wall by Face.
Constantin Stroescu
Unfortunately I cannot create roof by face because I cannot select the surface to complete this operation, I can only create wall by face with 10 CM thickness which is too thin for my project even though I wanted to create a roof
so my problem is creating a roof by face out of this mass, attachments would help
thank you for your time
From my observations:
Constantin Stroescu
