I want to do a curve massing drainage with 2 customize profiles. I tried use the model arc line and selected 2 profiles to create form, but can't do it. Anyone know how to to it?
Could you use a Model In Place Component and use a Sweep Blend? This will allow the use of Predefined Profiles!
If using a Mass simply create za Reference Line for the curve > Add Nodes > Draw shapes On Node plane > Select All > Create Form
Use your profile to create a Structural Framing Family and then you can do this in the Project:
Using 3D Snapping and Pick Lines, Structural Framing can be placed along the curved edges of floors, walls, etc., or along curved Model Lines like I'm showing above. It's magical. 😉
Hi @liang.yh
Thanks a lot for posting your question to the forums! Have the solutions suggested by @jay_colcombe @barthbradley helped with your issue?
We look forward to hearing back from you with more information so we can help you as a community!
Jonathan Hand
Industry Community Manager | AEC (Architecture & Building)
