Mass floors substituting for level at same elevation bug
KentBurns
Message 1 of 18
KentBurns
We have noticed what seems to be a bug, where we are working on a masterplan for a sloped site, so we have a number of sets of levels making up the Zones of the project. We're then massing, and using the Mass floors in each zone to get areas. All works lovely except we are noticing a strange behavour. It turns out that during the development two of the floor levels in two different zones are at the same Elevation.
It seems that revit will substitute the one Zone's level with the other, it isn't doubling the areas, but it is substituting, and will schedule in the wrong zone.
I assume under the hood the association with mass floors is done by elevation, and something is getting mixed up.
I've checked the journals to confirm that I can see the users resetting the mass floors to the correct assignements, but not see any of them changing them to the substitution (so no one is doing it, accidentally or no, but not telling me)
This is in Revit 2022
Hopefully an easy fix.
Replies (17)
Message 2 of 18
I don't get it. "Zones"?  As in  HVAC Zones?
Message 3 of 18
I don't think you are talking HVAC.  I do see that it is replicable among your team. Can you give us the steps to replicate on our end - or post a file?
Message 4 of 18
KentBurns
Oh yeah not HVAC zones, like zones in a masterplan, not a revit element as such.
Well, you could attempt to have two levels at the same Elevation in your project, create a Mass, set the Mass Floor to be associated with the level you created second (that's a hunch at the moment) and it will eventually shift to the first one... Eventually is a bit hard to define though. We're not constantly checking. But over the course of a day
Message 5 of 18
Okay, so I've got it now. Different Levels at the SAME Elevation.  So, you are saying that if you pick a Mass with Floors, Press Mass Floors and deselect one Level and choose another (at same Elevation), the Level shown under the Properties of the Mass Floor still read the "old" Floor Level?
Message 6 of 18
KentBurns
Almost there,
Select your Mass, and set a Mass Floor at the Level you created second at the same elevation.
Eventually, it will be saying the level you created second, without you having done anything
Message 7 of 18
Use a Scope box to scope Levels within each 'Zone'.
Message 8 of 18
KentBurns
Thanks ToanDN, but that's something different.
Message 9 of 18
KentBurns
Okay, once you have your Mass Floors applied, use Add to Set to put the Mass into a couple of design options and watch as it changes to the other level!
Message 10 of 18
KentBurns
It's creating new design options that is switching the Mass Floors
Message 11 of 18
Design Options??? You can't put Mass Floors into DOs.  I'm officially confused again.  he, he.
Message 12 of 18
KentBurns
Sure you can! you just can't put Levels in a DO. Give it a go, I set up a filter so I could see the magic happen when you add the mass into the option
Message 13 of 18
Maybe you're not talking about Mass Floors. Maybe you are talking about Mass Floors converted to a Floors.
Message 14 of 18
I said Mass Floor -not Mass or Floor conversion.
Message 15 of 18
KentBurns
Have you actually given it a go? or are you just assuming you're correct? I feel like we've diverted. But just select a mass, and add it into a design option, and the Mass floors will head in there as well.
Message 16 of 18
I don't think so.  It is to limit the levels to not intersect the masses outside of the assigned scope box.
Message 17 of 18
Yes, but we were talking specifically about Mass Floors.  You just threw Design Options into the equation and it got confusing again.  Masses can be added to DOs, but not Mass Floors ALONE.  Floor conversions from Mass Floor could be added to DOs though.  Anyways, just following along as best I can from Zones to Design Options. So far it's been quite a journey.  😉
Message 18 of 18
Recreate mass floor insides the Design Option and pick the correct levels.
