Mass divided surface offset not working.
p_barnett
Message 1 of 1
p_barnett
Hi, I have a divided surface on my mass and I'm trying to align it with another pattern, but the V Grid Offset won't move it enough to match what I want.
The highlighted pattern (blue) is the divided surface. Behind it in grey is a hatch pattern applied to a wall that I want to replace.
I've got the V Grid set to fixed distance, Justification beginning and offset 0.
The ruler shows I'm  428mm away.
Offset 428. And the grid goes the wrong way.
So try -428. And the grid appears to be in the same position.
I switch justification to End and incrementally try numbers. It moves towards the goal and I'm at 690mm.
Change to 700 and it jumps to the other side.
I can't get an offset to move the grid enough.
Am I missing something or is Revit?
Cheers
Replies (0)
