Mass - divide surface, Error: Constraints not satisfied, cannot generate gridlines
kimtj710
kimtj710
I want to divide the surface to attach pattern based curtain panel.
When I change the U grid and V grid parameter "Fixed distance, 0.2(m)", "Fixed distance>, 0.15(m)", it  shows error.
Default layout and number was "Fixed number, 10", both of them.
How can I solve it????
syman2000
Can you upload the massing so we can take a look.
kimtj710
I attached the file. I need the thin layer to be dividede.
UV grid cannot exceed 200.  Changing the V distance to 0.15 make it more than 200, hence it fails.
To fix it, either change the V distance to 0.45 and modify your pattern base panel to have subdivision built-in, or split the surface before dividing it.
RDAOU
@kimtj710
I would second @ToanDN on the 3rd option...Instead of having 1 surface spreading over 15 stories, Split it into 3 intervals (5 stories at a time)... expansion joints 😄
kimtj710
Thanks guys, I'll try it!!!
hoan.nguyenUSJLC
Community Visitor
Community Visitor
I''m having this problem too :((
