Mass deleting Filters
Anyone got any hints to mass delete filters in Revit? Have 300+ to remove...
L.Maas
If it is a one time job I would say, manually one by one.
It should be possible to delete 60 or more filters per minute. So 300 filter should only take a few minutes.
If it will be a repeating process I would say use the API. For example Dynamo (Dynamobim.com) should be able to do this.
Louis
Please mention Revit version, especially when uploading Revit files.
Hi @L.Maas,
In your notice, did you find any API for doing the same process?
Actually, I also have the same type of concern.
Karol_Piroska
you can delete unused filters (and other stuff) using dynamo
https://forum.dynamobim.com/t/deleting-unused-revit-filters/20346/2
hpz440
Its A.D. 2024 , Autodesk still mercifully/deliberately?/ cant allow FILTERS in LT...;
Facing&replying 1st post: I tried and cant confirm your 60/min efficiency. Thats kinda stupid 'advice'.Seriously.
I would ask rather: Why Autodesk, in Windows based product, still would not allow multiple selection in a selection box? ; Not even to mention how would it make job easier...
jsanders
Even Diroots OneFilter can't batch delete filter. It's sad
__________________________________________________________________________
ヽ༼ຈل͜ຈ༽ノ Onward still he goes, Yet ne'er looks forward further than his nose ヽ༼ຈل͜ຈ༽ノ
RSomppi
Try the Ideas forum. You can suggest it or vote it up.
