Managing Links Problem when moving Revit File
AidanHawkins
AidanHawkins
Hi Guys,
I created a model with 20 dwg links attached to it.
I then copied the model file to a different server for others to use
When they open the model, they get this prompt:
Do I need to move the CAD links to somewhere in the server?
If so is there any way I can group these cad links into one folder so that this is easier?
Regards
Aidan
constantin.stroescu
  • Save the CAD files into the same folder with the Revit file and copy the folder into the other computer.
  • While in Manage Links dialog ,use a Relative Path Type
Constantin Stroescu
AidanHawkins
Why Relative Path Type? and how do I do so
I tried to look it up on line but I couldnt find anything that was clear.
Relative paths are like you kept your coats in the master closet in house 1 and when you moved to house 2 you kept them in the master closet too.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2018/ENU/Revit-C...
