Making Floor Plan for new level : Drawing area blank
I am new to revit and learning it with the help of tutorials. I have already created the floor plan for the foundation and lower level, however when I tried to make the floor plan for next level, the drawing area is completely blank. It does not even shows the view symbols. I am not able to figure out the solution. I have attached screenshots for the same.Entry Level (Blank, nothing to draw upon)Entry Level (Blank, nothing to draw upon)FoundationFoundationLower LevelLower Level
Caed9
double click the scroll maybe you zoomed out, also check on Visibility Graphics. could you please Send the File in order to review it.
ennujozlagam
If you like to create another view plan go to elevations or sections add level. Thanks
Thanks for your reply. By the way I figured out myself. Actually I was using a different template other than the one recommended by the tutorial. I guess there must be different default visiblity settings in the two.
