MAKE SPACE FRAME ROOF COVER
Project2.jpgHi
I want to make side cover for this space frame structure so it cant been seen from outside.
Can you help me how to create it...
Thank U.
Ben
Corsten.Au
HI
As long as you can createa  a family with adaptive points... you may need 11 adaptive points above ( red )
and 10 adaptive points below ( blue ) and create a shape to enclose that..
( similar on the other sides depending on number of trusses )
Corsten
Building Designer
Thank you Ganesh...
Your answer dose help...
How if i want to make the cover a little bit curve  like this picture ?
Corsten.Au
Hi
I have crated a screencast for you...
You can use sweep ( a custom profile / shape  ) along any sketch.
but for adaptive family, theres a bit of planning required..
1. create a profile
2. create adaptive points ( these can be used to host on any other reference )
3. custom edge to sweep..
have a go..
pay attention to exact commands used for
1. points
2. setting plane
3. for profile etc..
just follow the steps and you will master it..
here iss a screencast.. start with adaptive family..
https://autode.sk/2zg3Lda
Screencast will be displayed here after you click Post.
65c1f5a1-e064-4791-a349-bd3479719e11
Corsten
Building Designer
Thanks  a lot
How can i add led strip in revit like that picture ?
Because after that i make the animation with Lumion
Thank You
