Make revit model ready to laser cut
8 REPLIES 8
Message 1 of 9
3703 Views, 8 Replies
I am in architecture school and a lot of our projects needs to be laser cut into physical models.
What is the easiest way to make your revit project ready to be laser cut?
is there a plug-in for unrolling surfaces or something like that?
thank you
8 REPLIES 8
Message 2 of 9
What software is running your laser cutter?
Message 3 of 9
in reply to: barthbradley
Cut-it
its based around curves. We usually hand draw every curve in rhino (which is a tedious project for bigger buildings)
I saw a dynamo plugin, that exported the faces that you choose to a drafting view (which kinda works) but it is sadly outdated
Message 4 of 9
RDAOU
@Anonymous
If by "outdated"  you are referring to the packages and node,  you can always download the newer packages and put the graph back together from the new nodes, it shouldn't be that hard...or download an older version of dynamo and the previous versions of the packages
You mentioned that you usually use Rhino for such task,... If your project is originally in Rhino / not in Revit, why not use grasshopper to unroll curves/surfaces!
Message 5 of 9
loboarch
Revit is not really set up for this workflow. I have done it in the past by exporting a view of the model/part to a DWG and then using that DWG for the laser cutter. It is a pretty manual process.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Message 6 of 9
RDAOU
in reply to: loboarch
@loboarch
@Karambaki  has quite some neat dynamo nodes for similar application in the Synthesize package … you should try it
Message 7 of 9
loboarch
in reply to: RDAOU
I have not worked on one of those projects for quite some time now, but it might be worth looking into next time.  😀
Jeff Hanson
Revit Help |
Message 8 of 9
Karambaki
in reply to: RDAOU
Thank you for the mention @RDAOU
@Anonymous  @loboarch
I've recently simplified the process even more.
Here's a documented video of the process ... It is in Arabic language, but anyone can understand it by simply following it.
https://www.aecedx.com/blog/revit/karam/k-laser-cutting-in-revit/
Karam Baki
Architect, Revit Guru, ACI
Facebook | Students' Work | LinkedIn
E-Mail : karam@aecedx.com
Message 9 of 9
jan.debieMA2QR
in reply to: Karambaki
amazing.
how can we get these scripts?
