Mullion intersection joins are set individually for each instance - either being continous or to break at join.
I guess it is not possible to have them both continuous as toggling one will affect the other.
Any clever workaround you want to suggest?
Currently, it is showing as the 3D view on the top left corner. It is using a Mullion Profile as shown on the bottom left corner. The goal is to have an intersections similar to the one showing on the right. This effect was achieved using an In-Place family to extent the horizontal mullion tips and use of the Linework tool set to <Invisible Lines> on the needed edges. Very time consuming to apply to to all the elevations we need to prepare
Assistant BIM/CAD Manager
Manchester, UK
Manchester, UK
