Make a roof with curves
Hello
Hope someone can help me.
I need to make an old roof Called, Mansard. I cant use the roof by footprint the old roof got curves that need to stay there....
constantin.stroescu
hello,
You can have a look on earlier post on Autodesk Revit Forum:
http://forums.autodesk.com/t5/revit-architecture/bell-curved-roofs/m-p/5261001#M82246
where the subject was discussed....
Constantin Stroescu
Thanks Constantin.... 🙂
But....Roof by Face.? Where do you find that one... Only got in this 2015 LT (look picture)
Thanks for any help
constantin.stroescu
Yes, indeed....this function does not exist in Revit LT.....
http://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/Revit...
You can try then the method proposed by alex60 in the same dialog....
The method consists in using two Roofs by Footprint and a a conection:
  • the first Roof (by Footprint) has a Cutoff at the height where the change of sloped is desired
  • the second Roof (also by Footprint),with a different slope as the first one lays on the Cutoff plane of the first Roof
  • from Component >Model in Place >Roof add a Sweep around the intersection line of the two first roofs
  • Join the three Roofs
The problem with this method, as I have shown , in that previous post, can be with texture maping when rendering...
Constantin Stroescu
