I am learning to use Revit and on Luminaire insert has problems:
1 - Doesn't have LED option as lamp
2- Light is defined in RGB not CYMK. Need to have Kelvin option to add color temperature. Filter is an extra part - usully it is a part in glass or gelatine.
3- I did download Revit 2014 and it is not showing IES file attach option.
@Anonymous
The reason is; you are using the default Revit OOTB lighting fixtures.
Hey there,
thank you very much to get back to me. But I could not understand all your infs as: what is OOTB? I am lighting designer and I know IES file property. I found some .rfa files of luminaire on AutoDesk Seek. I am searching how to build a family of a luminaire but did not find nothing on web yet. Do you have any material to share?
thanks in advance,
Natalia
