- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm working on an existing project where some of the lighting that was placed were generically modeled to be "x" length. I'm updating the generic models with IES files currently to give more accurate results for photometrics and ran into a situation.
Currently some of the lengths generically modeled are non-typical lengths (ex. 37' for continuous rows). Is there anyway in Revit to create a formula that has the lumen output associated with length or will I have to manually change it for each individual instance?
I tried using Fixture_Length * 500 (expected output per foot) in the luminare output field would work, however I'm unable to have equations refer to other parameters (according to error message)
