- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
It seems like this should be so easy but I've spent most of my day so far trying to make this happen. The problem is sorting the walls by wall thickness. Of course, to do a good material list for framing, you only need a little bit of information:
- Wall Height
- Wall Length
- Wall Thickness
- Stud Spacing
I can get all of this info easily but the core thickness rather than the entire wall thickness is what I'm after. I found a post where a forum user created a calculated value for 'Layer Thickness' using Material: Volume/Material: Area, and assigned 'Core Material' to the Material Comments in order to sort that info. The problem is that some of the walls that are actually 3 1/2" are being calculated as narrow as 2 3/4" of an inch.
I saw that this may be possible through Dynamo, before I jump to the Dynamo Forum and ask that question, does anyone have a thought on how else to achieve this?
Another perplexing thing that I found today and I think it may be new in 2023 is that there is a 'Width Measured At' field in available fields for wall properties, but I can't find that field anywhere in the wall properties themselves and can't find anything to speak of online about it, anyone have any info on this?
Revit Architecture 2022
Microsoft Windows 11 Professional
Dell Precision 5870 - x64 based PC - Intel Xeon CPU @ 3.80GHz, 6 Core. 80Gb RAM
Installed Add Ins - Enscape/StrucSoft MWF/LotSpec
