Lower shadow density in template
Hi, when I change the shadow density in Template it is grayed out as you see in attached. Thanks for help
chrisplyler
If a View Template is applied which controls those settings, then you cannot access them through the normal Graphics Display Options dialog. Instead, you must access them by editing the View Template.
I try to edit from the view template, but it is grayed out as you can see in attached.
You need to click on Lighting button, not Shadow button.
