Lost Walls ( Part 2 )
1 REPLY 1
194 Views, 1 Reply
Hi, I had a previous post this week about walls not showing up.  Thought I'd resolved it but doesn't seem so.
@ToanDN - do you recall the building pad issue where I sent you my file.  Can you see if you can replicate my new elevation.  I put a new East elevation as highlighted in yellow and the above is what appeared.  Missing walls.  This seems to be happening a lot with this  project and quite random.   Just wondered if you had any idea.  Nothing is switched off as far as I can tell.
1 REPLY 1
chrisplyler
chrisplyler
You aren't seeing what you want to see because the extents of your Elevation Views aren't capturing what you want to see.
