Long Ramp with 3 slopes
NERDASORUS
Message 1 of 11
NERDASORUS
hi
attached you will find a drawing for a ramp with three slopes, the thing is, since it has curvatures, I couldn't model it in one go! it automatically creates too many split lines, and i have to manually calculate the levels!!
what i did is, i divided the ramp into multiple sections and i modeled each part separately, this method takes way too much time, and i needed to manually calculate the level at the boundary of each slope (attached you will find a 3d snapshot of the ramp)
i would really appreciate it if anyone could show me they proper way to model it in one go, highly doubt that the method i used is the correct one 😛
Replies (10)
Message 2 of 11
cbcarch
Can you try using a Floor with edited points?
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 3 of 11
lassedamhus
Hi
If you create a floor as Cliff suggested and then use the split line tool then it should be quite easy.
Message 4 of 11
NERDASORUS
This is what I did guys! I modeled it as a floor.
The thing is when I modify the level of split line, it automatically inserts another!!
Is there a way to remove these lines?? Or could someone please show me how model it using the floor method, method I'm doing it wrong.
Message 5 of 11
lassedamhus
Yeah you can turn them off in your view template under floor if you expand it. Not at my computer right now so can't show unfortunately. But try to play around with the different options.
Message 6 of 11
cbcarch
In VG>Floors turn off Interior Edges.
Cliff B. Collins
Message 7 of 11
syman2000
I would model 3 part of floor slab and then use floor cut to cut away the edges so you won't get multiple points. See attached
Message 8 of 11
NERDASORUS
sir, that is perfect!!!
could you please show me how you've done it!?
Message 9 of 11
syman2000
Sure, to make the ramp continuous, you have to create 4 points slab. Here is the basic outline I have for the ramp.
Adjust the slab based on the slope
Then use the vertical cut tool
Cut off the edge and you will have ramp with smooth curve without needing additional lines.
Message 10 of 11
NERDASORUS
THANK YOU SO MUCH!!!
Message 11 of 11
tsui224567
Amazing!! However, how to determine the right direction of slope for this continuous circular path with same center?
