Log Post Diameter Parameters
dholmes8
dholmes8
Creating a simple log post that needs to be able to change diameter and height.  The height will flex as needed.  But when I adjust the diameter the reference planes will adjust correctly, but the log diameter does not follow.  How do I lock that extruded circle to the reference plane?  Family file is attached.
Accepted solutions (3)
Try this one...
...or this one...
dholmes8
Thanks!  Do you mind sharing the trick?  Comparing your BB2 to the original and I do not see what was changed in the set up...other than yours actually works!
dholmes8
One is controlled via a radius dimension (placed in Sketch Mode) associated to a parameter that is driven by formula =Diameter/2.
The other is 2 halves of a circle constrained to x and y Ref. Planes.  Enter Sketch Mode to see.
You can simply place a diameter dimension to the sketch.
