Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
LOD500 Revit Family
LOD500 Revit Family
yara.pereira
LOD500 Revit Family
yara.pereira
Hi all,
As a manufacturer (electrical; lighting and systems), what would you consider essential to have in a revit family in order to qualify as an LOD500? What parameters and graphical representation would you consider?
From what I have seen, there is no correct/direct answer to that (depends on the industry, project, local standards..), but let's say you're building your company portfolio, no specific project associated. I would like to have examples from your industry and experience!
Thanks in advance,
Yara Pereira
RSomppi
RDAOU
@yara.pereira
Anything beyond LOD400 becomes more of a client specific requirement. There is no consensus neither over a common national nor international standard for that.
As a manufacturer you should be concerned about the BIM objects standards ... you can check the NBS library on that topic they have quite some useful info you could use https://www.nationalbimlibrary.com/en/nbs-bim-object-standard
For more on LOI/LOD check also their BIM Toolkit
constantin.stroescu
in addition to what  RDAOU   has already mention in his post, I'll mention that , in order to create good Revit Family would be worth to consult  Bimstore Bible issued by  BIMstore :    https://www.bimstore.co/
You can download the last version from:
https://www.bimstore.co/bimstore-bible
Constantin Stroescu
