Locking to Levels
I've locked my floors and roofs(tops and bottoms) to levels.
I've created dimensions between these and locked these dimensions.
The expectation here, is that when I unlock, say, the dimension spanning the thickness of a floor, proceed to change the thickness of this floor, and then realign the levels to this floors top and bottom, everything would move in unison. It would be expected that I could move two levels and everything else would stay locked in place.
This is not happening, shifting levels is causing a mess.
I've gone over it, everything seems to be locked in place. What could be the issue? Is this not how revit should work?
The same issue happens if I try to change a levels height while keeping everything else locked.
