Lock these knobs
Lock these knobs
yes_and_no
Message 1 of 11
Lock these knobs
yes_and_no
I modified a revitcity book cabinet.
The shelf width flex ok, yet the knobs can't be locked to ref planes.
Can someone explain ? Family attached.
Replies (10)
Message 2 of 11
Basam.Yousif
You need a horizontal dim. snap to the center line of the knob. I set the dim to EQ but you can set to a param.
Before and After
Message 3 of 11
yes_and_no
I don't have problem with the knobs on center. The ones with "frame Wd" parametric dimension can't be locked when the shelve width is flexed.
Message 4 of 11
Basam.Yousif
Can you post a screenshot?
Message 5 of 11
yes_and_no
Here
Message 6 of 11
Basam.Yousif
I think I got it.
- The knobs are locked by a dimension directly instead of a ref planes. The only objects driven by dimensions and parameters should be a ref plane, which in turn moves objects.
- I would rather use full-word naming of parameters than the abbreviated format
- Use the 'Reveal Constraints' command (bottom of screen) to view all controls
- Flex the family and let things break, then align and lock to the right ref planes
- I changed the values in the family type for flex testing. See it attached here
Message 7 of 11
yes_and_no
I did not have "invisible dimension". They are tied to short reference planes that were either on top or below the model (for graphics clarity, Check it).
Can you flex-free the shelf width again after what you said without breaking the knob ties ? I don't have R23 to tell.
Message 8 of 11
yes_and_no
What bothers me is the reference planes flex ok as you change the shelf width but the knobs refuse to move with it and force the break.
See photo.
Anyone ?
Message 9 of 11
RDAOU
@yes_and_no
You need to fix the noob Family (See GIF and/or instructions below
  1. Edit the Handle/Knob family
  2. Create two (non reference) planes to define the handle/knob's width
  3. Edit the extrusion >> select the profile >> Associate it with the left/right reference plane
  4. Finish sketch and stretch/lock the planes created in step 2
  5. Open Front view >> tab select the reference plane and set it to Center Elevation
  6. Reload into cabinet (when prompted remove constraints and dimensions
  7. Align and lock the knob to the vertical plane
  8. Place a horizontal reference plane and lock the knob to that too instead of using dimensions
  9. Flex the width and now the knob should work as expected
Message 10 of 11
Basam.Yousif
The ref plane the dimension is moving is a different one than the ref plane the knob is locked to. Flex the family and break the current lock, then lock to the correct one.
Message 11 of 11
yes_and_no
I got them locked finally, as you demonstrated, but with many trials.
I wonder what is the lesson learn here. Was it because the knob family involved circle extrusions (I broke them into two semicircles) ? Surely not because of the reference planes alone in the knob family (bec I have to do many trials as per your ex).
