Locating or using Revit standard families of objects like beds
Hi!
I've used Revit a while now, but went from 2015 to 2017 on a new laptop.
I remember I used to be able to load in Revit families from an installed/standard into the model, like kitchenettes and beds etc.
Now my problem is (kinda silly) I don't remember where to find them or can't find them with the full installation of 2017.
Can someone maybe help me and tell me how to do it and where to find it?
Kind regards,
Marlissa
S.Jebakumar
Hi @Anonymous
You Should have your Families in following path if you have installed the Revit Content Libraries 2017 as well while installing Revit 2017.
C:\ProgramData\Autodesk\RVT 2017
if not then Install Autodesk Revit Content Libraries 2017 which will be available in the suit or CD provided to you.
Jebakumar
Jebakumar
BIM Specialist
