LOCATING FILL PATTERNS
tstewart
tstewart
Where  are the *.pat files found and how to install customized Fill Patterns?
hugha
OOTB Revit provides two example files with names revit.pat and revit metric.pat which are simple text files like most .pat files that can be found by searching the web.   Here are some web locations: https://www.hatchkit.com.au/HatLinks4.php
Here is how to load custom fills to a standard Revit installation from .pat files:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2018/EN...
hth,
Hugh Adamson
tstewart
Thanks, although I would like to make a custom Fill pattern (similar to Rubble), so that it displays correctly in elevations.
What do you mean by "displays correctly"?
