Load family in Revit 2018
When I choose "Insert"-->"Load family" in Revit 2018 Student Edition on Windows 10, the English folders under "Family Templates" are empty. Are they not installed as default?
ennujozlagam
@Anonymous  hello, make sure that your templates and families are install properly, yes they will install by default                << click HERE>> . if not you can check it <<click HERE>>.
- you can set the defaults by going to file > options > file locations and set from there. see attached. thanks
This is what I see if I go to "File"-->"New"-->"Family". If I go to "Load family", there are no supported files (.rfa or .adsk). Is it not installed correctly then? The link you sent me was for Revit 2015-2017, but are there still installations files from the earlier programs that I should use to install the families?
ennujozlagam
@Anonymoushello, which means you didn't install your templates and families properly. you should be seeing something like this when you load family please see attached.
you should follow this instruction on how to install your templates and libraries.
you cannot install from early version to latest version. you can copy the whole folder of templates and families but there will be an issue every time you load the family there will always be prompt message "the model is being upgrade" which i do not recommend.
try to open architectural template and see what happen
thanks
