litle problem
litle problem
seddikiislam04
litle problem
seddikiislam04
hello every body ,i have a problem ,when i make a normal wall(not in situ wall ) ,than i  make another wall which is stuck to the first , this second wall is made with (in situ )mode , the problem is that when i insert a window in this the first wall(not in situ ) the empty form do not make the hole on the second wall made whith in situ ,even whith attaching the two walls.
i work with revit 2019.
  thank you for anserwing me .
Join the Walls w/ Join Geometry. Then the Opening will penetrate the other Wall.
..or use a Void in Family that deep enough to penetrate the secondary Walls in the Project, check "Cuts With Void When Loaded", reload into Project and manually cut the openings using Cut Geometry.
