Global parameters to sheet
RADUACOSTOAEI
RADUACOSTOAEI
I want to show the list of global parameters on a sheet or view.
Does anybody know how can I do that?
Have a nice day.
syman2000
Sadly you cannot schedule global parameter. If you need to show, you would print screen the global parameter and paste the image on view or sheet
constantin.stroescu
You can , by using Dynamo, extract the list with Global Parameters as .csv file that can be eventually saved in Excel or Copy/Paste into the Text Editor in Revit.
Constantin Stroescu
Through a Schedule, you can Filter those Parameters that are "Associated With" or "Not Associated With" Global Parameters.  Is that what you want to do?  Find out which elements/parameters aren't associated to GPs?
constantin.stroescu
to refine my first answer, you can show the Global Parameters as a Schedule by exporting first from Dynamo in Excel , and then using a free plugin : Table Gen from DiRoots to turn it into Schedule.
1 -Dynamo
2 -Excel  ,3 - Table Gen to Schedule , and 4- Schedule in Revit
Constantin Stroescu
alaraJ3LSY
Is it possible to go the other way? I mean to create global parameters from an excel file?
