Try exporting or linking an FBX file from Revit to 3ds max. In many tutorials, the FBX file is recommended over the direct Revit path.
Jeff
i think this has to with the Archvison plug in which isn't included with 3ds Max
try installing the plug in for 3ds max
DarrenP
I am having the same problem. Did you find a solution?
