Linking in Architectural Model
AChiagoro
AChiagoro
I have run into an issue where when I link in an architectural revit model at "Internal origin to origin" it shows the architectural levels starting at 97'-0". This seems very odd, as I expected the levels to start at 0'-0". When I align my MEP level to the architectural levels, it doesn't match as shown in the attached captures. How can I match and/or adjust my levels or the linked revit model levels so that all levels start at 0'-0"
chubbard
you are using a different coordinate system than the architect. I assume the FF level is really 97' and not 0'-0'" you need to link origin to origin and acquire coordinates. It will adjust your coordinates to the architects. Your levels will need to use the survey point to read correctly
AChiagoro
Thank you !
