Linked revit filw not appearing in new camera view
17 REPLIES 17
Message 1 of 18
726 Views, 17 Replies
I have a linked revit file and I created a new camera view. The linked file is not showing up. I checked the visibility/ graphics settings --> revit links --> display settings for the linked file --> custom --> and the "by linked view" is greyed out and I can't select it. Only the by host view and custom view appear. It seems that there is no linked revit file in this new camera view.
When I select reveal hidden objects, the linked file is in purple but I can't select it to make it unhidden.
Picture attached.
17 REPLIES 17
Message 2 of 18
syman2000
For the context are they CAD link in or built with Revit objects? Check and see if Import category is checked off.
Message 3 of 18
in reply to: syman2000
it is a Cad link in another revit file. The linked file shows up in all the other views, though
Message 4 of 18
syman2000
Did you set it to by host and see if that fix the issue? Once you set to custom for both, it means one of the override may trigger for the CAD not to show up.
Message 5 of 18
I tried by host view and it didn't work. That was the default setting. Other views I can select "by linked view" and the linked file appears
Message 6 of 18
syman2000
Did you have numerous phasing in your model and the link model?
Message 7 of 18
its all one phase with the linked file...
Message 8 of 18
syman2000
Shared the model so we can take a look.
Message 9 of 18
There is no option to upload file
Message 10 of 18
syman2000
When you reply, just drag the file here
Message 11 of 18
attached
Message 12 of 18
syman2000
I am not seeing any issue from my end when I have CAD link into the other Revit file. So upload the CAD revit file and see if has to do with the file or something else.
Message 13 of 18
Can you tell me how you made a new camera view with the linked file visible/
Much appreciated!!
Message 14 of 18
syman2000
I've use the same camera from your file that you've created. So I am trying to see if it could the CAD link from your end. So I cannot be sure unless you have send the file.
Message 15 of 18
can you upload your file so I can review it.
Message 16 of 18
Message 17 of 18
syman2000
I look it closely and it seems Revit by default turn off CAD in the Revit link. I just have to set it to custom and go to import category and check on the CAD object.
This will show your CAD object on the camera view.
Message 18 of 18
awesome! thanks
