Linked model not visible in one view (in spite of having the same view template as others)
I'm checking my project's sections and a linked model is not visible in one of them in spite of having the same view template as the others. The visibility settings are set to by host view. When I select hidden objects mode its not visible either.
RobDraw
First thing to check is that the view template has all of the boxes checked.
Also, try creating a new section with the same view template. Sometimes views get corrupted and need to be recreated.
Rob
Uncheck "Far Clip" of the View. Also verify that the Section View Marker is positioned in front of the Link is the Referencing View.
Several other things to check:
https://www.ideateinc.com/blog/2013/01/missing-something-in-revit-view-33
I changed the far clip to clip without line, without changing the offset distance and it did it.
