Linked files always 'Not found'
mairh_tsek
mairh_tsek
Hello all,
I am working in some central model projects. Each time that I open the projects I need to reload the linked files as they are 'Not found'. Do you know why? They shouldn't be linked always ?
Thank you in advanced
martijn_pater
Perhaps set Path type in Manage Links to relative for the saved paths for the links. Might work better, but it seems like a network issue actually.
MostafaElashmawy
They should not do that if both the host model and the linked models are in the same location.
did you change the location or change the name of the drive or the folder having the files?
I think the problem can be solved following below link:
https://knowledge.autodesk.com/support/revit-products/troubleshooting/caas/sfdcarticles/sfdcarticles...
Mostafa Elashmawy
Perhaps someone is opening a linked file from the project to modify the link.  This will unload it.  They should rather open a separate session to modify the links.
mairh_tsek
Actually yes, I changed the name of the drive for connection issues, and also because it was too long, so I couldn't save the models (limitation in characters name).
